help me plz IR2000
  • walidcharifi
    • Feb 2011
    • 379
    help me plz IR2000
    I have a Canon IR2000 copier
    displays Rom error
    help me plz
  • teckat
    • 16083
    displays Rom error
    help me plz
    When the ROM Error message is displayed on the control panel, this will indicate an issue with the Flash DIMM on the Image Processor PCB.
    re-flash the system software/or replace the DIMM Assembly.
    When replacing the DIMM, you may be required to flash the system software to it's latest version.
    iR 1600/2000 FG6-9978-000, Dimm assembly.
    As a temporary work around, power on the iR while holding down the STOP key. This may boot the iR to a ready state and copies can be made.
    Service Mode=Additional Functions #
    • walidcharifi
      • Feb 2011
      • 379
      Where can I find THE DIMM
      AND HOW I Reflash
      I HAVE NEVER OPEN THE MACHINE
      • zaza
        MECANOGRAPHE
        • Mar 2008
        • 1095
        well friend tech teckat ..to reflash he should be have the frimware and sst ?
        BEST TECHNICIAN . NICE PEOPLE .
        • philip1davies
          • Feb 2011
          • 23
          If not I have the SST and firmware and service manuals
          Only problem They dont like E-Mail (they keep bouncing back)
          I may have to invest in some hosting and have a download section
          Or copy onto pen drive and send
          • teckat
            • 16083
            The machine or its accessory is upgraded by downloading firmware from a PC or by replacing
            the ROM DIMM.
            The firmware that may be upgraded is either of the following 3 types:
            • System software (machine; ROM DIMM on image processor PCB)
            • G3 multiport firmware (accessory; ROM DIMM on G3 multiport PCB)
            • Finisher-L1 (accessory; ROM DIMM on finisher controller PCB)
            Downloading of the system software and the G3 multiport firmware are done by way of
            the USB port of the image processor PCB.
            The ROM DIMM is made available as a service part, and upgrading may take place by
            replacing the ROM DIMM.
            Downloading of the Finisher-L1 is done by connecting a PC to the finisher controller
            PCB by way of downloader PCB.
            The ROM is built into the CPU, which is directly soldered to the finisher controller, and
            cannot be replaced in the filed.
            • walidcharifi
              • Feb 2011
              • 379
              thanks
