Can someone Help? I have removed intermediate Transfer belt cleaned also cleaned rollers also cleaned secondary transfer roller, still image is out of register "blurry" belt only has 35K clicks on it shouldn't need replaced yet? What else could it be?
Canon IRC 3200
settings,drums,sensors....If you make copies also scanner.More help if we see some samples.If it ain't broke, don't fix it
A picture is worth a thousand words -
do a ram clear and reset all the door specs then start from square one and eliminate options
and yes the belts do fail early depends on the maintenance and usage low volume is worse than high volumeComment
What did you clean the ITB rollers with? use IPA And clean
Is the belt correctly positioned on the rollers.
have you tried running a copy with the ITB Cleaner assy out ?Comment
Before u do a DCON CLEAR- u need to print out the P PRINT Settings- so u will be able to re-input the DCON Settings
READ PDFfor Laser gear adjustment
iR3200 TP03-1.pdf
Check this ITB DRIVE GEAR UNIT below FOR WORN TEETH
Pain to replace~~~~~~~
Swing unitl.JPG**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
U need to advise Poster what to do before an attempted CLEAR of anything in a imageRunner
Like printing out P PRINT Settings/ and or User Data settings
Wake up Coffee.JPG**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
