E220 iR8500
  • bakaoni666
    • Mar 2010
    • 56
    E220 iR8500
    Need HELP>>>>
    I've been replace the scanlamp for iR8500.
    then Error E220 showed up.
    i tried to use the old Scanlamp and everything is normal ( it lights red first about 2 sec in the outside of the lamp then become Green)
    Please help me...
  • CT Copier Repair
    • Mar 2010
    • 304
    E220
    Main cause The fluorescent lamp activation is faulty. The light adjustment sensor is
    faulty. The light adjustment control PCB is faulty. The inverter PCB is
    faulty. The reader controller PCB is faulty.
    Condition
    0000 The fluorescent lamp does not reach a specific intensity within 10
    sec after it is turned on (if the room temperature is 10
    C or lower,
    within 60 sec). Or, the activation detection signal (FL-DTCT) does
    not go OFF within 5 sec after the fluorescent lamp is turned off;
    during shading adjustment, the activation detection signal (FLDTCT)
    does not go ON within 60 sec after the fluorescent lamp is
    turned on.
    MAke sure the heater is in the proper position it has to line up
    B
    • teckat
      • 16083
      Originally posted by bakaoni666
      Need HELP>>>>
      Please help me...
      Did u Complete the CCD-ADJ, LUT-ADJ and LUT-ADJ2 adjustments
      make sure the Fluorescent lamp is mounted correctly with opening to the left.
      Check and make sure the Inverter PCB is correctly grounded
      • bakaoni666
        • Mar 2010
        • 56
        It's work. But i took the black plate above the lamp. is it ok? because if i put it the scanner didn't want to move. Sorry for late confirmation. Thanks a lot.
        I'm looking for iR8500 Service manual ... Do you have it?
        • teckat
          • 16083
          what black plate ???
          • bakaoni666
            • Mar 2010
            • 56
            I'm sorry i don't know its name. it's above the lamp.
            • Matoku
              • 173
              Black plate you mean, the lamp cover? ( antireflection plate)
              You need service manual?
              < email me at mel2tobpinai@gmail.com.
