OK, here is the situation, I have 2 Canon iR4570 and we need to swap all data between these 2 devices: Mailboxes, Address Book, Department ID and Settings (like IP, SMTP info, etc).
I was planning on doing this manually by doing a backup and export on each one of those features but with over 90 users on both devices it will be a very time consuming task... and then most likely I will end doing some manual entry as well...
Then it occur to me if we can just swap the internal hard drives between these devices and accomplish the task in a faster and easy way.
What do you think, is this possible?, what would be the steps, I have replaced hard drives on computers but not in these iR4570...
Please help and thanks!
