Tech question quiz
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Tech question quiz
    ir xxxx series. What's wrong?
    Printing working normally.Fax incoming also work .
    Don't work:coping,sending fax.
  • Herrmann
    • Jan 2006
    • 792
    Shot in the Dark:
    User administration engaged and no proper rights set?
    If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
    • zoraldinho
      • Mar 2008
      • 5015
      Originally posted by herrmann
      Shot in the Dark:
      wrong,but good shot.
        • 16083
        No FAX
        Additional Functions>
        System Settings>Restrict Access to Destinations
        to Enable the Fax Driver> Allow the Fax Driver TX>ON
        No Copy
        Service Mode>Copier>Function>Clear>MNCON>then press OK
        Turn of MEAP-DISP
        • zoraldinho
          • Mar 2008
          • 5015
          Originally posted by teckat
          Additional Functions>System Settings>Restrict Access to Destinations
          Don't think like Einstein.Wrong again.
          • charm5496
            • 2387
            sounds like department ID is enabled, but incoming faxes and unknown print jobs are allowed.
            • zoraldinho
              • Mar 2008
              • 5015
              To complicated.User usually make this issue by mistake.(little help)
              • Herrmann
                • Jan 2006
                • 792
                ok, lets begin simple: faulty start button/keybord
                • zoraldinho
                  • Mar 2008
                  • 5015
                  That one is banal.Sorry dude.
                  • Herrmann
                    • Jan 2006
                    • 792
                    false respectively no allocation of the paper sources to the functions; false respectively no allocation of paper output to the functions
                    • zoraldinho
                      • Mar 2008
                      • 5015
                      You are very smart tech but more luck next time.
                      • steve schofield
                        • May 2010
                        • 117
                        no dadf??
                        • zoraldinho
                          • Mar 2008
                          • 5015
                          Originally posted by steve schofield
                          no dadf??
                          If you have only cover you can also make copy,scan or sending fax.
                          • Herrmann
                            • Jan 2006
                            • 792
                            Forgotten or broken Scanner Connection to the host Mashine respectively false settings in service mode, so the box thinks, it is Printer only
                            • zoraldinho
                              • Mar 2008
                              • 5015
                              You are full of ideas but to complicated.
