ir 550 memoy issue
  • pontiac
    • 420
    ir 550 memoy issue
    first time i have seen this message , when you go to run copies the screen says memory full can not make copys. thanks for replys
  • teckat
    • 16083
    Start off by going into Copier>Function>HRD-DISK and selecting SCANDISK first.
    Perform the Scandisk, then once completed, perform a FORMAT
    Format the Image Server Hard Drive in Service Mode COPIER>FUNCTION>HRD-DISK>Format.
    Note- thatthe Image Server Hard Drive is not the same as the Print Board Hard Drive and no software needs to be reloaded after formatting.
    • livancicm
      • Sep 2008
      • 96
      Last time i replace the Image
      Processor PCB
      • teckat
        • 16083
        Processor PCB
        Why,? this should be a simple fix as posted above/
        have done it numerous times in past/ although not recently
