Change language on clc 1110 e colorpass z800
  • Alessandro72
    • Jul 2009
    • 31
    Hi all,
    I bought a Canon CLC 1110 with ColorPASS Z800 from Germany and I would ask how can I change the language of Italian in both devices.
    I would also like to know if the ColorPASS has a fixed IP address or acquired from dhcp.
    Thanks for your help.
    https://t.me/pump_upp
  • CT Copier Repair
    • Mar 2010
    • 304
    need system software for both the colorpass and the clc unless its allready installed
    you can use dhcp but better to set static ip
    • Alessandro72
      • Jul 2009
      • 31
      Thanks,
      I also have an office in ir3220 can use the same software?
      to access at ColorPASS the first time how can I do?
      I do not know who was setting the origin.
      Thank's much
      • charm5496
        • 2387
        Originally posted by Alessandro72
        Hi all,
        You need to get into the setup of the colorpass and restore it to factory settings and you can then choose the language you want upon reboot. On the CLC I am not sure where you would change the language on it or if you even can.
        And Z800 can pull DHCP or use a static IP address.
