a case for everybody..currently experiencing a jam code on ir 105 0205 coming from LCT. 1. RUN AND TESTED COPIER PULLING PAPER FROM ALL TRAYS WITH NO JAM. 2. REPLACED FEED TIRE KIT FROM LCT, PROBLEM STILL EXIST. 3. ALSO TRY REPLACING VERTICAL FOAM RUBBER ROLLER WITH NO EFFECT AT ALL. NEED SOME EXPERT ADVICE OUT THERE..THANKS
ir 105 jam code 0205
