Image fading
  • bineshpaul
    • Jul 2010
    • 43
    Image fading
    Dear All,
    In my canon IR6570 the image is fading, scanned copy is attached.. pls help me
    Regards
    Binesh
  • teckat
    • 16083
    Looks like a poor paper issue
    Scanned CQ
    How do Prints look/ post a PG5
    • bineshpaul
      • Jul 2010
      • 43
      I am using 80gsm paper and also if it is a paper moister problem then the second page of the paper should be clear. while i am printing the same issue happening.
      • teckat
        • 16083
        Paper moisture does not effect all sheets the same way
        u have scattered quality issues on your posted image/
        run off 10 pages of PG5 Test prints> post a couple> report back
        • Herrmann
          • Jan 2006
          • 792
          I agree with Teckat, looks like moist Paper. But it could also be a Transfer/Sep Corona issue.
          First at all, make sure, that the wires are not worn out, if in doubt, restring.
          Second: Lower the two Sep-Wires by turning the screws at the backside 1 turn clockwise and raise the Transfer Wire by turning the screws 1 turn counterclockwise. In some cases this did the trick for me.
          If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
          • dhanesh
            • Jun 2010
            • 63
            dhanesh, kerala
            DHANESH
            • teckat
              • 16083
              • kuby
                • Oct 2007
                • 1409
                The way I check for a moist paper problem is run 20 copies. Then put the paper back in the machine and run another 20 copies on the other side. If the copies look OK then, you have moist paper.
                • Peter Sim
                  • Sep 2008
                  • 445
                  May be you can polish the drum
                  • teckat
                    • 16083
                    • KenB
                      Geek Extraordinaire
                      • Dec 2007
                      • 3944
                      Could also be bad spots on the drum which polish won't help eliminate.
                      I had a similar problem many years ago with an airborne chemical that kept doing about the same thing to a small Canon machine. (The customer's neighbor made custom golf clubs and it was some sort of chemical used in the process.)
