IR 7200 jammed paper issue
  • agha
    • Feb 2011
    • 10
    I am facing the following problem with my IR 7200:
    - Papers will jam between
    - I had changed the drum fingers, the transfer, and the high voltage but i am still facing the same issue.
    Can anyone help
  • agha
    • Feb 2011
    • 10
    Hey,
    - Papers will jam between transfer corona and drum
    • teckat
      • 16083
      Originally posted by agha
      Hey,
      Jam Code is ?
      Paper jams from what paper source/
      use of-deck/cassette/mf/df/scan/copy/prints ???
      • agha
        • Feb 2011
        • 10
        thanks teckat for your reply.
        Below the answers:
        - No Jam Code
        - Paper will jam for all the functions presented in your question.
        Directly when the paper will be between the transfer corona and the drum, it get jam.
        Thanks,
        • teckat
          • 16083
          look in jam log & error log
          Are there burrs on the paper guide of the transfer/separation charging assembly?
          Remove & re-seat transfer/separation charging assembly
          Check rotation of the two separation belts & Is Feed Fan on ??
          Check service mode copier>option >body>tp-sp-xx (xx denotes the cassette or deck that is having the jam issue)
          Make certain that the setting for all the locations is 0 =plain paper for
          TR-SP-C1/2/3/4/MF/DK
          Check and adjust below
          COPIER>OPTION<BODY>FUZZY
          Use it to enable/disable fuzzy control and set the environment.
          • The change affects the current level of pre-transfer, transfer, and
          separation charging.
          • Setting it to 1 through 3 will make it independent of the environment
          sensor.
          Setting 0: Fuzzy control (default)
          1: low humidity environment mode (current level will be lower than standard)
          2: normal humidity environment mode
          3: high humidity environment mode (current level will be higher than standard)
