canon IRC3220 electric problem
  • msmy
    • May 2010
    • 123
    Hi,
    I just bought used Canon IRC3200. The problem come when I power up the machine, the electric is everywhere at the machine. Please help me to solve this prob.
    thanks
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    In brand new machine is also electric every were.What do you mean?
    • msmy
      • May 2010
      • 123
      for your information, I can't touch the machine. if I touch, I'll get electric shock! however, the machine is working well...
      • mehta
        • Oct 2010
        • 11
        Please check earthing (ground)connection...
        • zoraldinho
          • Mar 2008
          • 5007
          Ha ha ha ha.How can you do that?You did not tested before?.One copy will be enough.
          • mrfixit51
            Lead Service Technician
            • Oct 2008
            • 1975
            As has been "hinted" at by zoraldinho ;-) the issue is going to be the electric service, the receptacle, not the copier itself. It does sound as if there is a floating ground, and this should be addressed by a competent electrician before the copier is used any further!
            • teckat
              • 16083
              Originally posted by msmy
              Hi,
              thanks
              Call the Electrician
              what country are u in ???
              • msmy
                • May 2010
                • 123
                thank you. I solved the prob.
                • gensys
                  • Jan 2011
                  • 324
                  Hi my Friend zoraldinho
                  As I have understood on this site not only technicians, but also philosophers tell all aphorisms
                  The Road will be Mastered by >>> the Going...
                  • teckat
                    • 16083
