Hi Guys!
I need a little help.
At my customer there is a IR3225 at the implamenting / installation, a trial or demo version of the Universal Send kit was installed. It allows the user to use this send fucntion for 100 sending.
We've ordered the Universal send kit and I installed as the manual required and followed the instrucions.
So Cannon.com/lms/license then give the license code and gave the serial number and got the activation serial.
I activited on the asset then rebooted the copier. then the worst came; The trial version was out of service ( 101th was dennied) eventhough If I tried to activate the send kit again ( maybe forgot to do something) it said it is activated
so I've got a machine which has got an activated universal send kit and out of used trial send kit....and the result , i can not use the send function.
What is the problem?
Maybe the trial should be unactivate? how?
Thank you in advance!
Cheers!
Norbert
Cheers!
Norbert
