CANON IR2520
  • tulipano
    • May 2010
    • 124
    CANON IR2520
    QUALCUNO SA COME SI CONFIGURA LO SCANNER SIA TWINE CHE SCAN TO FOULD SU QUESTA MACCHINA? GRAZIE MILLE ,QUALCUNO MI PUO' INVIARMI UNA CONFIGURAZIONE SCANNER?STO AVENDO MOLTI PROBLEMI
    Does anyone know HOW TO CONFIGURE SCANNER TO SCAN Fould both twin and on this machine? THANK YOU someone can 'SEND ME A SCANNER CONFIGURATION?am having MANY PROBLEMS
    • 16083
    Scan to where ? Pull Scan ??
    send is a option on iR2520 !
    • tulipano
      • May 2010
      • 124
      important to get it to work somehow
        • 16083
        explain -what are u trying to do /
        Scan to PC ??
        Scan and Send ??
        Scan to Copy ??
        DF to SCAN ??
        Scan To E-Mail ?
        All the above~~~~~~~~~~~~~~~~~~~~~
        • tulipano
          • May 2010
          • 124
          Scan to PC ??
          Scan and Send ??
          Scan to Copy ??
          DF to SCAN ??
            • 16083
            Scan to PC ??
            Scan and Send ??
            Scan to Copy ??
            DF to SCAN ??
            well what is the story ?
            you can not SEND on this 2520 model unless u install the Option
            SEND SPECIFICATION/
            CLR SEND KIT-Y1 (standard on i models, optional on non i models)
            Canon-iR2520-IR-2525-IR2530.pdf
            check your PM/ SENT U THE DRIVER GUIDE TO READ
