secret combination keys of ir machines
  • jacky
    • Jun 2009
    • 61
    #16
    This topic quite interesting. Anyone want to share more?
    • teckat
      • 16083
      #17
      Originally posted by m43l
      i just want to know, if you know you can tell to me
      there is no secret combo for imageRunners
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5018
        #18
        Try to be a good technician not Houdini!!
        • m43l
          • Mar 2011
          • 14
          #19
          thank you very much for your all comment.
          • zoraldinho
            • Mar 2008
            • 5018
            #20
            • johnyb
              • Feb 2011
              • 167
              #21
              Lick your finger, put it into the air to see which way the wind is blowing, if the wind is blowing to the East then boot up holding the 3 and 9 key and stick your right leg in the air at the same time,
              Or if the wind is blowing to the West then boot up holding the 1 and 7 key and stick your left leg in the air at the same time.
              This will enable you to get into G33k Mode, then if you press number 2 key this will then let you into tot4lg33k mode!
              Hope this helps.
              OR RTFM!
              • teckat
                • 16083
                #22
                Enough with the nonsense > Don't need to push more garbage
