Canon IR2020i Transfer Problems !
  • tecchie
    • 118
    Im posting this message with a lot less hair than I had an hour ago! I have a customer with a Canon IR2020i that is producing faint splotchy prints(almost a tree bark) on the image area on about 1/3 of the back of an 81/2 x 11 page. Almost looks like the transfer roller is not coming in contact with the drum on the back side. I've done all the usual things. New transfer roller, springs and bushings. Stopped copy half way through and image is fine on drum. I even checked hinges on door. Didn't progressively happen but was all at once according to customer. Almost seems like a voltage or bad ground issue but checked that and everything seems fine. Here's the kicker. If i run a double-sided copy the second side is fine. Has anybody experienced this out in the field? Even with my many years of Canon experience these machines still manage to "humble" me on occasion. Thanks in advance.
  • Brian8506
    • 1664
    You answered the question when you said the 2nd side is fine. You've got bad paper. High moisture content in it. Once it passes thru the fuser on the 1st side it takes the moisture out and the 2nd side is fine. Get a nice fresh ream and I think you'll solve your problem.
    • teckat
      • 16083
      Check the Ribbon Cable between the HVT and the DC Controller.
      • tecchie
        • 118
        Brian
        Thanks for responding. Thought of that but if I take a single-sided copy and run it back through the bypass tray for the other side i get the same faded result (tried a fresh ream just to make sure). Thanks again...
        • tecchie
          • 118
          Do they go bad or just lose their connection?
          • D_L_P
            Self Employed
            • Oct 2009
            • 1196
            In my experience that usually is their paper. However, in a few cases I've adjusted the transfer current to fix this. Not sure where to change that in the 2020 service mode. Or the "density" setting from 5 to 7 or 8.
            • tecchie
              • 118
              Well guys I tried all of the above with no success. Talked to other Canon dealers and they've never seen this problem (my luck). Definetally a transfer voltage problem. When I register paper as thick stock or heavy it darkens the light areas but print is still fuzzy from the tree bark its putting on the page down the back side of the copy. It happens with everything (copy, faxes, prints and reports). Its almost like the transfer is leaking voltage because when i do double-sided the second side is fine. Any more help would be appreciated. Thanks.
              • teckat
                • 16083
                transfer roller bias
                A negative bias, sheet-to-sheet bias, or positive bias is applied to the transfer charging roller according to the type of sequence.
                The negative bias is applied at the prescribed timing to moves the toner from the transfer charging roller to the photosensitive drum for cleaning.
                The sheet-to-sheet bias is lower than that applied during printing and it is applied at the prescribed timing to prevent the toner remaining on the photosensitive drum
                from adhering to the transfer charging roller.
                The positive bias is applied to transfer toner images from the photosensitive drum to paper.
