iR5070 firmware
  • Dimacop
    • 43
    iR5070 firmware
    I have a iR5070
    And I doubt a firmware of it and even iR5570/6570?
    I would upgrade the firmware before more formats would make sure
    Att:
    Roberto
  • toantam
    • 63
    Dear friends!
    I HAVE IR3045, AND MACHINE GET E602. SOMEONE HELP ME
    BY THE WAY, DOES IR4570 AND IR3045 THE SAME PART.
    THANKS.
    • mrfixit51
      Lead Service Technician
      • Oct 2008
      • 1975
      Originally posted by toantam
      Dear friends!
      THANKS.
      You should have started your own post out in the main forum, instead of inside someone else's thread, since your question has nothing to do with the original posters question.
      But to answer your question, the hard drive is the same in the 3045 and the 4570. That is the part you need to fix your E602. The System Software that is loaded on the hard drive is not the same for the 2 models though.
      • mrfixit51
        • Oct 2008
        • 1975
        Originally posted by Dimacop
        I have a iR5070
        Att:
        Roberto
        Hi Roberto,
        I have re-read your post several times, and I still am not sure if you are asking a question, or making a statement of fact. Please try again ;-)
        • Dimacop
          • 43
          Originally posted by mrfixit51
          Hi Roberto,
          Hi mrfixit51,
          I have a ir5070
          and would like to upgrade the firmware
          More have the firmware ir5570/ir6570 Ver.40, 03 and 42.01
          My doubt is whether the firmware ir5570
          works in ir5070?
          thank you for your cooperation
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5018
            Hi mrfixit51,
            I have a ir5070
            works in ir5070?
            Yes it's the same software.(example from this firmware)
            Software
            Subject:
            (#)iR5070/5570/6570 System Software v40.03/Language v40.03/HD Format v0011
