Canner problem canon ir2520
  • tulipano
    • May 2010
    • 124
    salve ho un problema con una canon ir2520 nella configurazione dello scanner twine, qualcuno sa come si installa?
    Hi I have a problem with a canon ir2520 scanner configuration in twine, does anyone know how to install it?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Dude, this is the second time you posting your thread twice.anyway if you don't have install SEND KIT Y1 you need driver for scanning.
    Color Network ScanGear is a 32-bit TWAIN-compliant scanner driver that enables computers on a network to use a Canon iR series color digital copier as a scanner.
    Also you need software to get scan into computer like acrobat,irfanview....
