Canon IR 6000 Scan feature Question:
  • ybnews
    • Oct 2008
    • 94
    How do I use the SCANNER feature on my IR 6000?
    When I hit the Scan key it goes to "Press Online key to use scanner".
    When I do that it just sits there "Waiting"
    Is there some way to program this feature,
    or do I need to download drivers for the scan feature?
    Thanks,
    Dana Lewis
  • charm5496
    • 2387
    you need to download and install network scangear on a PC. Also your 6000 needs to be connected to your network and have an IP address asigned to accomplish this.
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5005
      Thanks,
      Dana Lewis
      Color Network ScanGear is a 32-bit TWAIN-compliant scanner driver that enables computers on a network to use a Canon iR series color digital copier as a scanner.
      Also you need software to get scan into computer like acrobat,irfanview....
      • santosasmile
        scaning pages
        can I scan multiple pages in one file?
        just 100 pages in one file pdf?
        • Dedy.P
          • 67
          yes, you can.
          • Dedy.P
            • 67
            Thanks,
            Dana Lewis
            i agree with charm said, also you need office software installed on your pc to get it work.
            • santosasmile
              Originally posted by Dedy.P
              yes, you can.
              acrobat? how it works? cause its works with photoshop, or another software. and to create one file, from many slide, i must combine it all manually
              • Dedy.P
                • 67
                if you using acrobat, choose create PDF from scanner in file tab, select network scangear(you must install network scangear first)
                put your document in ADF, and press scan in your pc.
                • mr.daus
                  • Apr 2011
                  • 98
                  use scan gear tool driver for scan function
                  email me for help firdaustrish@ymail.com
                  firdaus +(62)8195002007 firdaustrish@ymail.com
                  • KenB
                    Geek Extraordinaire
                    • Dec 2007
                    • 3944
                    "Acrobat" is mentioned numerous times in this thread.
                    Keep in mind that this isn't Acrobat "Reader", but rather Acrobat Professional or Standard.
                    Reader can't create files, so it only makes sense that you can't scan with it.
                    Reader is free, while the others are most definitely not.
                    • santosasmile
                      thanks all
                      thanks all, I've got it, its work now....
