i had this error code when i pulled out the fixing unit out. when i try to print out, the paper will jam at fixing, the when i pulled out the fixing unit to remove the jam paper the error appear. does anybody knows this problem?
If fixing/feeding unit closed sensor PS5 is dirty or has malfunctioned, or if MSW5 and MSW6 (fixing/feeding unit open/closed switches) are not actuating properly, it is possible an E004 will occur when the fixing drawer is pulled out.
clean sensor PS5, (between the two switches), and to check and adjust the fixing feeding unit open/closed switches 5 & 6: 1. Open the fixing feeding unit drawer. DoorSw_1.jpg 2. Open the upper left vertical pass door and remove the side cover and vertical pass door. DoorSw_2.jpg 3. Remove the upper left vent cover. DoorSw_3.jpg 4. Remove the four screws and the connectors for the vertical pass assembly and lift the unit out of the machine. DoorSw_4.jpg 5. Note how the fixing unit connector 'A' (at the top rear of the fixing assy) makes electrical contact with connector 'B', and how it also is used to actuate the fixing unit open/closed switches msw5 & msw6 'C'. DoorSw_5.jpg DoorSw_6.jpg DoorSw_7.jpg 6. Clean the sensor PS5, also check the switches for continuity using your volt/ohm meter, replace one or both if necessary and adjust the leaf spring actuators so that switches msw5 and msw6 de-actuate BEFORE the fixing feeding connector breaks contact when the drawer is pulled out. The switches should actuate and de-actuate pretty close to the same time. DoorSw_8.jpg NOTE: Be sure the power is removed from the machine prior to this procedure and make sure to clean any toner and paper dust from the connectors, switches, and sensors of the fixing feeding drawer assembly prior to re-assembling.
