IR7200 mage quality problem
  • madu132
    • Dec 2008
    • 65
    I got problem with IR7200 image quality.
    There is a part of the image bolder and sometimes blurry, it happen in staight line.
    I attach the image so it can be clear.
    what could the source of this problem
    thank you
  • KingKogo
    • Mar 2011
    • 19
    Check lower fix roller and check the bearings on it. Could be poor fixing.
    • madu132
      • Dec 2008
      • 65
      thx KingKogo, I found the problem. yes it is the fixing.
      • KingKogo
        • Mar 2011
        • 19
        Great! Good to hear!
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5007
          Can be more specific please?
          • madu132
            • Dec 2008
            • 65
            I found that they add some kind of coating on damage part of the roller so it can be still in use without having to give marks on the paper. ( I didnt ask what kind of coating is that, possibly its commonly used by used copier business to prolong the life of the fixing roller)
            and because that coating, the pressure on the roller is sometimes not even which can make the problem like I posted before.
            unfortunatelly I am not have the picture right now so it can be seen clearly.
            • teckat
              • 16083
              probably used a bike tube patch
              READ THIS>>>
              on re-coating
              recoated fuser roller.pdf
              • nizam
                • Mar 2011
                • 40
                i see the copy ir 7200, I got the problem with 8500 i am clear the problem. The open back cover and drum disc wheel FS7-0011 gear and steping gear replaced now the problem is ok sent message
