Poor Fixing / Patchy on iPRC1
  • pga
    • Jul 2009
    • 67
    [Misc] Poor Fixing / Patchy on iPRC1
    Dear all,
    Do anyone got ideas on this matter? Appreciate someone can share with me.
    I had changed whole fixing unit,ITB belt, 2nd transfer unit, primary transfer roller. It happened on intermittent with any type of media.
  • teckat
    • 16083
    Originally posted by pga
    Dear all,
    Remove>Inspect & Replace the Secondary Cleaning Unit Assembly (FM2-8070-010).
    The 5 REAR pressure plates that actuate and support this assembly are probably broken . =Plates= FC7-0863-000
    There are 10 small plates shown in picture below in red circle 5 Front side/5 rear side
    This unit is rated for 100,000 prints / copies.
    If unit is old Replace it/ if not replace broken plates-inspect both sides
    • pga
      • Jul 2009
      • 67
      THe unit i already changed. is new part number......Any else???thx....
      • teckat
        • 16083
        run Pg5 prints single color
        re-check ITB Belt for your hand prints/ finger prints = oil from hands
        • pga
          • Jul 2009
          • 67
          All color happened on different media but same location. Confirmed all media no oil before put in print...
          • teckat
            • 16083
            PRIMARY CORONA ASSEMBLY= FM2-2496-000
            check the Grid PLATE & Post wire
            Grid plate causes a lot of issues=FC6-1056-000
            did u run the single color PG5 PRINTS ????
            • zoraldinho
              teacher-guide-expert-guru
              • Mar 2008
              • 4999
              Make print on plain paper but set to heavy.If you still have issue it's not fixing problem.
              • pga
                • Jul 2009
                • 67
                the whole primary unit changed, still occur.
                Test the plain paper using heavy/thick paper type, not issue. It happened on intermittent.
                • teckat
                  • 16083
                  replace the drum
