imageRUNNER ADVANCE C2030i Error code E227 and "Check scanner" user message
  • magc
    • 30
    [Error Code] imageRUNNER ADVANCE C2030i Error code E227 and "Check scanner" user message
    Hy guys!
    I've got some of these copiers with error codes E227 when I cheked Service Mode log. Customers told me about a "Check the scanner and close the front door". They should turn off/on the copier and the problem was fixed.
    What could it be?
    Any idea?
    Thanks a million in advance!!
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Try to disconnect and then connect the power supply harness
    connector.
