Canon IPF610 printhead overheat
  • adremby
    • Dec 2010
    • 6
    Good day!
    Well, I'm printing a lot. At the nozzle print check magenta, cyan are absent full, yellow for a half; all blacks are fine. But plotter prints very slowly becoz of overheating colors nozzles. I need to print only black-white prints. Does anyone know about turning off overheating control of printhead pf-03 for Canon IPF610..??
    Thanx in advance!
  • MrB
    • Nov 2009
    • 147
    best to replace the printhead
    If you have that amount of nozzles missing, you defo need a new one
    As you said, it's a PF03 for that printer
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      Originally posted by adremby
      Good day!
      Thanx in advance!
      Printhead Overheating Protection Control
      0012-6501 This printer performs printhead overheating protection control when an abnormally high temperature is detected in the printhead.
      The printhead can overheat, for instance, when the print operation continues for some time with no ink supplied to the nozzles.
      The overheating protection control function prevents a print head nozzle from becoming clogged or damaged due to excessive heat.
      Overheating protection control is performed based on the temperatures detected by the head temperature sensors in the nozzle arrays. If overheating is detected in
      a single nozzle array, overheating protection control is performed at either of the following levels according to the temperature.
      Protection level 1:
      If the printhead temperature sensor detects a temperature above the limit, the carriage stops at the scan end position printer in the direction of travel according to
      the carriage's scan status.
      Then, wait control is performed to allow the printhead to cool naturally. When the printhead temperature drops below the prescribed value or 30 seconds have lapsed
      since detection of the abnormal temperature, printing resumes.
      Protection level 2:
      When the head temperature sensor detects an abnormally high temperature, printing stops immediately, the carriage is moved to the home position, and the printhead
      is capped. In this case, an error code is shown on the display.
      • adremby
        • Dec 2010
        • 6
        I'm talking about the cheap not about best. As u see, I said that all blacks are fine, why should I get new one pf-03 if I'm printing just white-black prints..??
        • adremby
          • Dec 2010
          • 6
          2 zoraldinho:
          This manual I've read already. My printhead is going on protection level 1. but u can find some info on principal scheme about temperature sensors. This way I wonder. I'd like to choose by myself printhead out of operation or not.
          • WOETC
            No real way out without new printhead. Newer heads are tougher and come with a firmware upgrade,(though it's a few behind) which improves thermal characteristics.
            • adremby
              • Dec 2010
              • 6
              New heads needs new firmware..?? As I know - new firmware (1.36 and higher) will block printhead when some (? about quantity) nozzles get clogged. Coz I'm printing using non-original inks and a lot it's apeear for me in about month.
              Anyway I've had old firmware which just ask to press "online". Next step I've discribe above.
              "No real way".. exit exist always.. -)
              I wanna play with temperature sensor. Lets game begin.. -))
                • 16083
                Maintenance Kits are now assigned as service parts
                for all iPF models.
                TP08.pdf
                DOWNLOADS FOR LARGE FORMAT PRINTERS
                Canon in South & Southeast Asia
                • WOETC
                  Good luck, I don't want to reverse engineer the firmware.
                  • adremby
                    • Dec 2010
                    • 6
                    I didn't talk about editing the firmware just about sending "right" signal to temperature sensor.
                    • MrB
                      • Nov 2009
                      • 147
                      Still confused, why you want to "Cut Corners", when we have given you the solution
                      All the problems you having will go away with a new printhead (And in the box you get the new firmware "FREE")
                      • adremby
                        • Dec 2010
                        • 6
                        It's becoz of money. Your solution costs 500$ with "free" firmware.. -) My solution costs 0. What should I choose..??
                        • mark921
                          • Dec 2010
                          • 110
                          Heaven help you if youre using third party inks...they are print head killers. We have an IPF 8000s and an IPF 9000, and tried a set of third party inks in the 8000, and it was rough...needed a new print head in no time flat, and later found the prints lacked any archival quality what so ever (faded indoors with only ambient light). I understand economies, however, when these heads go bad you have to replace them or you end up out of business.
                          • WOETC
                            i understand why you want to save money, however these machines have an operating cost which users factor in to the charges for prints. Most people aren't using these for printing recipes at home.
                            • mark921
                              • Dec 2010
                              • 110
                              Just to add emphasis... DO NOT USE THIRD PARTY INKS in these units. They are not the same. You loose a lot of your color fidelity, they dont usually dry properly, and they WILL DESTROY the heads. The savings on the ink is more than offset by the cost of the heads, and the ill will you create with your clients by producing an inferior product.
