iR2230 networking printer, setup question
  • y2bne1
    [Misc] iR2230 networking printer, setup question
    Hello,
    I am trying to setup our Canon Image runner 2230 to be connected to our network. Currently, it is directly connected to one of the workstations via usb cord and the printer is shared. Everything works. We do have several people who stay late who have complained about not being able to print when that computer is turned off. I noticed that there was an Ethernet port to plug into. I've tried weekend after weekend to get this to connect, but have failed miserably. I am starting to lose faith and ANY advice would be much appreciated. I am not the IT department for my company but just a guy who is above average when it comes to computers.
    We recently purchased a TrendNet Print Server. Model TE100-P1U. When I connect everything, from the PS control panel, it shows the printer as connected but with the status OFFLINE. Can't figure out how to get it to work. I tried plugging directly into the network with the Ethernet cord, but can't figure it out. I've read other posts so, I don't know what Bootrom is running or the firmware. If you want to know anything else, please let me know and I can perform it. Even pictures if you want!
    ANY ADVICE WOULD BE HELPFUL!!
    • 16083
    READ
    UFR II Printer Kit-E3 or PCL/UFR II PrinterKit-E2 is installed.
    Printing (optional)*
    upgrade this machine to a high-speed network printer
    * The optional UFR II Printer Kit is required.
    Remote User Interface (optional)*
    Network Scanning (optional)*
    *The optional UFR II Printer Kit must be installed
    on your machine, and Network ScanGear software must be installed on your computer.
    Network Interface
    Machine can be connected to a
    network using Ethernet (standard equipment). Connecting to a network enables you to use utility software, including the Remote UI, NetSpot*, NetSpot Console, etc.
    NetSpot enables you to manage and make various settings for the printers and copiers connected to a network from a PC. NetSpot Console enables you to perform the same operations as NetSpot, but from a Web browser.
    *NetSpot and NetSpot Console can be downloaded from Canon's Web site
    (Canon U.S.A., Inc.).
    Mail Box Function (optional)*
    *The optional UFR II Printer Kit is required.
    Faxing (optional)*
    *The optional UFR II Printer Kit and Super G3
    Fax Board are required.
    • y2bne1
      Thank you for your prompt response. Is there a way to confirm if I have the UFR II installed?
      Note: I did notice that the printer name is ir2230 UFR II
      • y2bne1
          • 16083
          Originally posted by y2bne1
          Well, from the pdf manuel you supplied, I was able to bring the printer online! But I am having trouble locating the printer to install. Looking through the manuel, it says that "Install the driver according to the following procedures indicated in the manual
          for each driver:
          • If you want to use the UFR II printer driver
          See the procedure for dynamic installation in Chapter 2, "Getting Started," in the
          UFR II Driver Guide."
          Where can I locate the UFR II Printer Driver? A link would be amazing!
          Thanks!
          see Canon link below for 2230 drivers = Windows & Mac
          Canon U.S.A. : Support & Drivers : imageRUNNER 2230
          • y2bne1
            Well, I can't say this enough. Thank you!! Your first post with the manual was a HUGE help!! Thanks so much! I was able to bring it online and install the driver and get it to test print.
              • 16083
              It's all about support , thanks
              • thetechguy
                Re: iR2230 networking printer, setup question
                Originally posted by teckat
                [ATTACH]9004[/ATTACH]READ
                Network Interface
                Faxing (optional)*
                I have a customer who has a Canon IR 2230 and they were wanting to be able to print to it across the network. It has a network card on the side of it, but when I go onto the printer control panel and system settings, there is no network settings option. Does this mean that they do not have the required kit even though there is a network card on the machine or do I need to log onto the printer with some kind of "admin" id/password to see this feature?
                  • 16083
                  Network Settings only appear only when the appropriate optional equipment is attached.
                  as in the UFR II Printer Kit---------------------------------------------------------
                  do u receive a prompt that says
                  Enter the System Manager ID and Password
                  after u hit System Settings ?
                  UFRII Printer Kit E3 INSTALL .pdf
                  • thetechguy
                    Network Settings only appear only when the appropriate optional equipment is attached. as in the UFR II Printer Kit--------------------------------------------------------- do u receive a prompt that says Enter the System Manager ID and Password after u hit System Settings ? [ATTACH]16905[/ATTACH]
                    It did not have the optional equipment. Thanks!
                    • dateand
                      I also had the same problem on his machine there rj port 45 but when I plug the cable there is no response,
                      do i have to add UFR II kit on the machine.? thank you
