IR 2200
  • hope gh
    • Aug 2025
    [Error Code] IR 2200
    Hi
    Error code IR2200 00064 000 Whats it mean.
    This is the machine I had problems with before, after they changed the power board (the heater control board) it worked but I got a loud humming came from the laser. could the laser have died?
    What's the problem, can someone supply the parts.
    Regards
    P
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Code mean The power supply PCB is faulty or The DC controller PCB is fault.
    • teckat
      • 16083
      Originally posted by hope gh
      Hi
      Regards
      P
      Check the setting of COPIER>ADJUST>DEVELOP>DE-DC in service mode.
      Compare this value with that of the service label. If the setting is found to be out of adjustment, set the value back to door specifications.
      make sure u have the new Switching Regulator PCB- see below
