Hard reset Canon IR3100c
  • Roblei
    • Aug 2025
    Hello,
    Can someone help me how i reset the IR3100c (full rest). Need to clear passwords etc.
  • charm5496
    • 2387
    execute the PWD-CLR in service mode.
    • Roblei
      Tx Charm5496!
      But how do i get into the service mode? Its reads (om screen) now that i need to fillin a ID-number and password, i dont have that!
      • teckat
        • 16083
        Originally posted by Roblei
        Tx Charm5496!
        are u a tech ???
        Perform MMI Clear:
        SERVICE MODE=
        Additional Function key, the 2 and 8 keys at the
        same time, and then the Additional Function key once again
        1) Go into Service Mode level 1.
        2) Hit Copier.
        3) Hit Function.
        4) Hit Clear.
        5) Hit MMI and select OK.
        6) Wait for the OK button to return and reboot the copier.
        • charm5496
          • 2387
          additional functions (2,8 at same time) additional functions
          copier>func>clear>pwd-clr turn off and turn on should clear that out for you.
          • Roblei
            That did the job, id-number and password is gone!! tx for the info Charm!!
            But i see in the mailbox settings still some previous users in it, can i i remove it form the canon also?
            • charm5496
              • 2387
              depending on the firmware on your device you can do a full reset by going to additional functions>system settings>initialize all data settings. If that function is not there you can back into service mode to the same area Copier>Function>System>HD-CLEAR and that should do the trick after cycling the power.
              • teckat
                • 16083
                HDD “Initialize All Data/Settings” is supported by the following Devices:
                iR 105+ /9070/ 8070/ 6570/ 5570/ 5070/ 4570/ 3570/ 2870/ 2270
                iR 7105/ 7095/ 7086/ 5075/ 5065/ 5055/ 5050/3245/3235/3230/3225/3045/ 3035/ 3030/ 3025
                iR C5068/ C5058/ C6870U/ C5870U/ C3170U/ C3170i
                CiR C5185/ C5180/ C4580/ C4080/ C3480/ C3380/ C3080/ C2880/ C2550/ imagePRESS C1
                U need to be Careful with HD Clear on this series/
                u could pop a E602 Error
                think u can select chk-typ 6 to clear address book under HD CLEAR, also think u need SST for this chk-typ 6 function
                • tinnyjay
                  • Oct 2009
                  • 663
                  Hello,
                  The hard reset these machines need,is just droping out.
                  "Who loves the roses,must also bear thumbs"
