Locate the Version of your Installed Canon Printer Drivers
    • 16083
    [Misc] Locate the Version of your Installed Canon Printer Drivers
    Determining the Version of the Installed Canon Printer Driver
    To obtain information about your installed driver, such as the version, following the steps below.
    Canon Fax, UFRII, PCL5e/PCL5c/PCL6 and PS3 Drivers:
    1. Go to the Printers folder in Windows.
    2. Right click on the installed printer and select Properties.
    3. Select the Device Settings tab.
    4. Click the About button.
    Fiery PS Drivers:
    3. Click the About tab.
  • mrfixit51
    Lead Service Technician
    • 1975
    Originally posted by Canon.Tech
    How does one find the IR3220 Fiery version, C1 or C2 & what is the difference please?
    I believe from the Printer Configuration Page you print out.
    • ReproKev
      • 273
      The C1 has a power switch on the side. I'm pretty sure the C2 does not.
      • mrfixit51
        • 1975
        You are correct sir!
          • 16083
          imagePass C1 v2.0 Intro TP04-1.pdf
          imagePass C2 Intro TP06 116.pdf
            • 16083
            Before attaching an imagePASS-C2, verify that Color imageRUNNER C3220/2620 has software/firmware of the following versions or later:System Software (MN-CONT)
            82.03
            The imagePASS-C2 can only be turned ON/OFF using the copier’s main power switch. This feature is made possible by the imagePASS-C2’s PCC PCB.
            The Power Control Circuit (PCC) allows the imagePASS-C2’s independent AC Power Supply to be controlled by the copier’s main ON/OFF switch. In order to accomplish this, a signal is sent along the Open Interface Cable from the copier to the imagePASS whenever the copier’s main power switch is turned ON/OFF. The PCC PCB monitors this signal and uses it to determine whether or not power should be sent from the power supply to the motherboard of the imagePASS. The main power switch on the copier will dictate whether or not power is sent to the motherboard of the imagePASS.
            In order to turn OFF the imagePASS-C2 (from a full running state), the imagePASS-C2 must first be shutdown via the operation panel of the copier. Then the copier’s main power switch can be turned OFF.
            When servicing the imagePASS-C2, it is important to turn OFF the copier’s main power switch (as this will also turn off the imagePASS-C2) and to disconnect the power cable from the imagePASS.
              • 16083
              • mrfixit51
                • 1975
                Many thanks. I was a little confused, as I know now I we have an IR3200 with the C1 firery, but the version says 2.1 I guess that is the firery firmware version!?
                Correct, that is the info in the first paragraph of the configuration page I spoke of...
                • bipc
                  • Sep 2009
                  • 194
                  Thanks for the info, never had the chance or plesure to work with any kind of image pass, small place with only small companys so mostly small o medium canon machines, biggest we have worked with was a IR5000 copier standalone, but still great to see wath's going on around
                  Life is a learning continuum...
