ir3030 dual line fax setup
  • tsb13
    • Mar 2009
    • 28
    how to set up dual line fax for two different lines so they can send/receive for two different doctors in same office. Thanks in advance for your help
    Tsb13
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    If i understand wright.You have:
    2 different fax lines.
    1 fax machine
    2 doctors.
    • mrfixit51
      Lead Service Technician
      • Oct 2008
      • 1975
      Unless you use fax forwarding, to channel the different received phone line's documents to separate email accounts, the two lines are indistinguishable. Sending out faxes will pick up on whichever line is available....
      • zoraldinho
        • Mar 2008
        • 5018
        Doctors have money.Great opportunity to sell one more fax machine.
        • tsb13
          • Mar 2009
          • 28
          Thanks! I'll just do that!! Thay wanted to let this new doc. use there fax with a different phone #.
