iRC3380i with ghost image
+ More Options
Posts
  • Blues Guy
    • Aug 2009
    • 216
    [Misc] iRC3380i with ghost image
    Good day to all,
    I have a iRC3380i with these problem. When you do multiple copies from copy or print 1st and 2nd copies will be ok but the subsequent copies you will notice a ghost image just like poor cleaning. I have change the ITB cleaner unit assembly a new set but the problem still persist.
    Its only on black color for other color cyan,yellow and magenta no problem if you try on single color mode. I believe is just a adjustment in the service mode. Can anyone can guide me on these problem ? Thank you.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Technician always need most important information first. " COUNTER"
    Check MISC in service mode .Usually is drum issue.
    • teckat
      • 16083
      Originally posted by Blues Guy
      Good day to all,
      make sure they did not force feed the wrong BLACK toner in printer/ Have seen this done before on this model from desperate customers
      • Simons
        • Jun 2008
        • 490
        I would agree about the black drum being the problem.
