Canon Imagerunner Harddrive
  • y83883
    • May 2025
    I have a canon ir330s, that has water damage. i need to remove the harddrive before disposal. Can any tell me where the harddrive is located and what it looks like?
  • vandezo
    I don't know
    • 161
    hdd
    there is no hdd in ir330s
    hdd 2,5'' place on printer board, but still function for copy or fax..
    • y83883
      according to the specs, it has a 2.1GB Hard Disk
      • AndrewQOI
        If the unit has a HDD in it. Then you will find it behind the rear panel. You may have to slide the print board out to see, I'm not entirely sure. It has been a long time since i've replaced one in that machine.
        You'll recognize it when you see it.. its a small laptop harddrive.. 2.5"
