All imagePROGRAF Series_Parts Counter Maintenance Kits_HIGH PRIORITY
  • teckat
    • 16092
    [Misc] All imagePROGRAF Series_Parts Counter Maintenance Kits_HIGH PRIORITY
    Publication is to inform technicians that Maintenance Kits are now assigned as service parts for all iPF models.
    TP08.pdf
    Depending on machine model and firmware version, a warning will display on the operation panel when a parts counter is about to exceed its respective part life expectancy. If this warning is ignored, an error code will eventually display rendering the machine inoperable. To determine which part/s is needed to resolve this warning, a Print Status Report or Print Inf. Report is required to access this information. If the machine is down and unable to print, utilizing the Status Monitor software or L-Printer tool will allow technicians to retrieve this information to a PC.
  • bipc
    • Sep 2009
    • 194
    Thanks for the info, got 2 IPF's on the shop for internal use ( 8000 and 8100S ) and a couple at customers and this saves a lot of time, thanks once again
    Life is a learning continuum...
