iR 2016 error message
  • dany&endah
    after removed a paper jam on my iR 2016, the machine always shown an error message like :
    "system error : E007"
    help me please for solving this problem...
    thanks a lot
  • CanonHPTech
    • Apr 2007
    • 235
    Was the jam in the Fixing/Fuser Assy.? Because a E007 is related to a non-detection of the Fixing Film/Upper Roller not spinning correctly. Please check the condtion of your Film also check the green handle in this area for paper jam removal if it is broken or removed, may also cause this error. Good luck sir let us know how you make out.
    The glass maybe half full, but less is more...
    Printer + Fax + Copier = Jack Of Many Trades,
    but Master Of None
    Color Copier = Not A Color Printer
    InkJet MFP = Not A Fax Machine
    B/W Copier = Not A Press
    Finisher = Deal Closer (salesman, not accessory)
    Copier Tech = Admin's Stress Ball (Scapegoat)
    • dany&endah
      E007 again
      someone please explain me,what is Fixing/Fuser Assy?thanks
      • Gleq
        • Feb 2007
        • 72
        Thanks to hp tech,
        but it looks as if your not a technician, or? if not please get one to sort u out, or else great harm to your copier.
        thanks
        • etsmultan
          • Apr 2007
          • 131
          hello,h r u?can u pls send me Ir2016 service book nd trouble shooting codes with simulations.my id is etc_new@hotmail.com nd mmazhar.javed@gmail.com
          • dany&endah
            i'm sorry sir Gleq, i just a newbie in the copier world
            • zkafs
              • Jun 2007
              • 29
              helo dany! let me explain in bahasa indonesia rest of you dun mind me! kamu ngecek bahagian heternya dahulu,cek apa heter filmnya robek gak! kalo robek diganti atau kamu cek handle patah kerana biasanya handel heter atau pusingan heter film ngak selari..yang penting kamu lihat aja bahagian heter ( pemanasan ) ok..bro..selamat mencoba..wow my bahasa indonesia is all over sorry bro.
              • CanonHPTech
                • Apr 2007
                • 235
                I am sorry sir. But I agree with previous poster Glig, if you are unsure what a Fixing or Fuser Assembly is, then it is best to call for service. I am never one to turn someone away, or critize ones knowledge, but a Fuser is a pretty essential aspect or concept to the Print/Copy Process and it aplies whether your repairing a small laser fax machine thats worth $100 or a large press style copier that is worth over $25,000. There are plenty of websites dedicated to explaining the Print/Copy Process and what a Fuser is. Unfortunately there is not enough time to explain such a thing on this forum. If you are just getting started in this industry- good luck my friend! I wish you all of the best. Do your homework first though. I believe someone has previously posted a Toshiba Factory version of copier basics/training. Start there. Take care.
                but Master Of None
                • dany&endah
                  Thanks to all
                  thanks to all especially for Mr CanonHPTech. I've found the fixing film and ordered it..
                  • vandezo
                    I don't know
                    • 161
                    halo mas
                    salam kenal..
                    just 4 information..
                    di Indonesia. dealer resmi canon ada di PT. samafitro, atau MCM jakarta..
                    kalo mau ganti unit pemanas..
                    or u can Pm me
                    • meta
                      • Mar 2008
                      • 16
                      di sini banyak orang indonesia juga toh.. wah lumayan neeh jadi ga pusing klo mo nanya...
                      soale basa inggeris brantakan wekekeeee...
                      • monasayed
                        ir 2016
                        thank y very much to help me
