c3380i - fax log and Memory RX inbox password
  • kuby
    • Oct 2007
    • 1408
    Is there a way to clear the Fax log and the Send (email) logs for this machine? Also how can you delete the password for the Memory RX inbox?
  • teckat
    • 16083
    CAUTION: Any images in mailboxes will also be deleted!
    Clear the job logs
    • Enter the Service Mode
    • Press "Copier"
    • Press "Function"
    • Press "System"
    • Press "Chk Type" press "1", press "OK"
    • Press "HD-Clear", press "OK"
    • Exit Service Mode
    • Cycle power off and back on
    • kuby
      • Oct 2007
      • 1408
      Will try this Monday....thanks
