irc2300 - film assy
  • y_us1982
    • Aug 2025
    irc2300 - film assy
    anyone had a suggestion what suppose i do to solve film not rotating properly problem. when i'm doing full adjustment gradation, the black color a little bit dismiss from other c,m,y color. this cause a little bit shadow when i'm printing in color mode,seems like the black a little bit late printout on the film. i had ask other tech, they tell me to clean up the roller inside the film assy. is it can solve this kind of problem? otherwise, can cleaning blade cause this problem?
  • y_us1982
    sorry, its irc3200.
    • CT Copier Repair
      • Mar 2010
      • 304
      clean the fuser
      sounds like good advice
      • teckat
        • 16083
        Originally posted by y_us1982
        sorry, its irc3200.
        U mean the ITB BLACK SHEET
        READ THIS
        TP03-1.pdf
        • y_us1982
          II.Color Mis-Registration in the sub-scanning (paper feed) direction due to Excessive Toner Build-Up: (this is what i mean, sorry cause i can't describe it properly.)
          READ THIS
          [ATTACH]9219[/ATTACH]
          • teckat
            • 16083
            Read the tech pub i attached
            • Matoku
              • 173
              y_us,
              I think I know your problem.
              try these,
              1, cleans all sectoin of the ITB belt.-all the drive roller inside the itb belt and the belt inner side.
              2, lubricate the cleaning blade using toner>not lubricant
              3, go to service mode * 2&8 * > copier>function>claer>R-con, dc-con.
              4,do auto colour gradiation full adjust for plain and heavy paper.
              I have do this many times and it works.
              good luck.
              • teckat
                • 16083
                Originally posted by Matoku
                y_us,
                try these,
                good luck.
                that issue was four months ago-
                Clearing RCON has nothing to do with posters issue !!
                before u post info to clear RCON & DCON u need to advise poster to print out P PRINTS , so settings can be put back in
                all this info is in the Pdf link that I posted/
                there are many different Registration issues on this model, it is not a cut and dry fix
