canon irac 5045I will not see usb stick
  • trapster
    • Aug 2025
    i have a problem with one irac5045i that refuses to show a usb stick plugged into the side for multi media memory.
    if you click on access stored files (top right of screen)
    you then get four boxes one of which is
    MEMORY MEDIA
    i click on that then insert the usb stick and it just stays blank ,have tried other usb sticks.
    i have gone into user settings > preferences >display settings>store location settings and memory media is turned on.
    i have also go into service mode level 2 and turned on all the usb options that i can see
    machine has below options
    direct print for pdf
    pcl
    ps
    its so strange as its the only machine we have that does not show a usb stick when inserted.
    any ideas would be usefull
  • trapster
    dont worry its been sorted
    meap options in preferences was turned on
    it seems you can have meap and usb media only one or the other
    • charm5496
      • 2387
      That is correct. If you turn on the Meap for USB it blocks your memory media functionality.
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5017
        it's good to know
        [ATTACH]9232[/ATTACH]
        • bipc
          • Sep 2009
          • 194
          yep good to know for future reference
          Life is a learning continuum...
