IR2570CI
  • williekriss
    • 39
    IR2570CI
    What should I check and replace for this code.
    "E000020-0081
  • PatrikeN
    "E000020-0081
    Remove the drum and vacuum the printer, clean the little optical sensor in top of the hole where the drum were.
    • jacky
      • Jun 2009
      • 61
      Patch image read sensor window is frequently soiled with toner on toner receptacle
      Clean the Sensor.
      FH7-7629-020
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5017
        "E000020-0081
        Cleaning Patch image read sensor window is temporary solution.If you have this issue randomly,check developers life.
        • CanonSco
          Man About Town
          • Jul 2010
          • 368
          Originally posted by Canon.Tech
          I would advise yo to call a trained tech on this model.
          If you are unsure, or cant find out what E020-0081 is, then take Canon.Tech's advice for this model.
          Yes, I am a nerd.
          Gaming PC - check. Raspberry Pi - Check. Custom ROM on phone - check. Thick glasses - check.
          • zoraldinho
            • Mar 2008
            • 5017
            Amen
