IR C3080i code: E000-990-000
  • verderacer
    • May 2008
    • 158
    I believe this has something to do with waste toner?
    Any help appreciated
    Ricoh & Microsoft may pay the bills but Un*x saves my ass every day.
    MCSE/CCNE/ENS and other crap...
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5017
    Are you shore about this code.Maybe E990-000
    E990 Error in the waste toner shutter
    0000 When the output of the waste toner shutter opening and shutting detection
    sensor doesn't become "H" when it WMUPR period after the sleep returns after
    eight hours or more pass, the door opening and shutting is detected or main
    power switch turns on.
    - Check that the drum unit is properly installed
    - Replace the waste toner shutter sensor
    • teckat
      • 16083
      Error E990 ???
      When the process unit black locking lever is locked or released, it in turn opens/closes a waste toner shutter mechanism, if this does not occur properly an E990 error code may occur.
      Check the Cam Lead mechanism (on inside process frame) for any broken gears or a broken cam lead itself, item #24 FC6-9403-000. (See attached image for parts location).
      FIGURE 513 PROCESS FRAME ASSEMBLY
