C3200-C1 removal
  • kuby
    • Oct 2007
    • 1410
    C3200-C1 removal
    I need to remove a bad ImagePass C1 from a C3200. Is there a board I have to put back in the copier when I take the other one out and remove the imagepass box?
  • teckat
    • 16083
    Originally posted by kuby
    i need to remove a bad imagepass c1 from a c3200. Is there a board i have to put back in the copier when i take the other one out and remove the imagepass box?
    i/f pcb + c boot rom-
    [ATTACH=CONFIG]9256[/ATTACH]
    • kuby
      • Oct 2007
      • 1410
      I know I have to remove the I/F pcb but is there a card I need to put back in its place?
      • mrfixit51
        Lead Service Technician
        • Oct 2008
        • 1975
        There is no card needed to replace the I/F board, and if it is to be a copier only, then it already has the C boot rom in it from the imagePASS configuration...
        • kuby
          • Oct 2007
          • 1410
          It is going to be networked, the ethernet port seems to be live, I was trouble shooting the machine to find out what was wrong and confirmed the system software in the machine through the ethernet card in the copier.
          • mrfixit51
            • Oct 2008
            • 1975
            The ethernet port will work to load software, and allow the customer to utilize RUI as it sits. But to print to it, you will need a network boot rom and the Color Network Multi-PDL Printer Kit-
            A1 or A2. I can't recall, but I think the NBoot rom is in that kit, Teckat has a better handle on what is in them, I think he has the Canon configurator book at his disposal...
            • kuby
              • Oct 2007
              • 1410
              Yea already got one on the way....thanks
              • charm5496
                • 2387
                The PDL printer kit A2 will work on the 3200 and 3220 and comes with the boot rom and what is called a SURF board which assist in the processing of images.
                • mrfixit51
                  • Oct 2008
                  • 1975
                  Thanks for the "assist" Charm... ;-)
                  • charm5496
                    • 2387
                    anytime dude
