Canon ir 2016 "scanning" error
  • altan
    • Jun 2025
    Hy guys
    After paper jamming in Canon iR2016 I removed all peace of jammed paper, when I switched on it made all test and ready to use , but when i pressed ready botton to make copy , it gives a message ( scanning) but the scanner never moves , no any keys respond . Plse help
  • mrfixit51
    Lead Service Technician
    • Oct 2008
    • 1975
    I believe some copiers pre-feed paper to the registration area before starting the scanning process. If you still have a paper feed problem, that may be the symptom you are experiencing. Try running a report from the engine in service mode, this eliminates the scanner all together, and then you can concentrate on the paper feed mechanism's...
    • altan
      Still not fixed. Maybe some peace of paper still inside?
      • mrfixit51
        • Oct 2008
        • 1975
        Have you done as I asked yet? Trying to print from the service mode instead of the document scanner will help pin down a possible paper feed problem...
        • altan
          At service center said me to change FM2-4053-000 Image processor PCB assembly board. Is it can so easy to broke?
          • Borsody75
            • Mar 2011
            • 83
            As I understand well, you are an operator, you called the service, and the technician said, he had to change the image processor pcb to solve the problem, and you don't believe in it? Or you are a technician???
