how to scan with canon ir 6570
  • blu3sky
    • Jul 2010
    • 25
    [Misc] how to scan with canon ir 6570
    I scanning a document and i want to edit with pc. I already install Network Scan Gear and the problem, scanner is offline. Anyone can tell me how to make the scanner online??
  • mrfixit51
    Lead Service Technician
    • Oct 2008
    • 1975
    You need to discover the copier in the Network Scan Gear tool, or directly set the IP of the copier in that window. Once that has been done, the software will now communicate with the copier. Touch SCAN on the copier op panel, and select Online. Place your documents in the feeder and initiate the scanning.
    Also you may be under the impression that Network Scan Gear is a scanning software. It is not, it only acts as a driver, you will need some piece of software to initiate the scanning like Acrobat, or Nitro PDF Professional, or any other software that can "import" data...
    • charm5496
      • 2387
      go to the scanner tab at the top of your control panel and choose "online" if you do not have a scanner tab then you neeed to go into service mode and turn it back on.
      COPIER>OPTION>USER>NW-SCAN
      • Set to "1" to enable the scan tab.
      • Set to "0" to disable the scan tab.
      • blu3sky
        • Jul 2010
        • 25
        thank's mrfixit but there isn't SCAN on the copier op panel
        • blu3sky
          • Jul 2010
          • 25
          I have done set NW-SCAN to 1, but the scan tab still nothing
          • mrfixit51
            • Oct 2008
            • 1975
            Have you restarted after making the change? Most changes only show up after a reboot.
            • blu3sky
              • Jul 2010
              • 25
              yes, i have restart.
              I have done solve my problem, to display the scanner tab on the copier panel go into service mode
              COPIER>OPTION>BODY>UI-EXT
              • mrfixit51
                • Oct 2008
                • 1975
                Glad you found the solution!
