HDD failure IRC 3220
  • Mb29661
    Today when I started it it displays E0602-0003, HDD failure. I ran a check on the disk (1 and 9 pressed at boot) and it got to download mode. I turned it off and on again but only to now have E6002-0002 instead. I did the check again but that didnt help. I understand that my next step is to reload the firmware, correct? But I dont have the SST or the firmware, could someone be a kind sole and share that with me. :-)
  • charm5496
    • 2387
    make sure you get the instructions on how to load and use the SST if you have never touched it before and I would recommend getting a new HDD as well. Do not use the one with E602 code again as it is probably going to fail on you
    • Mb29661
      I have never used SST but I am a very experienced IT specialist, I am also very good with electronics.
      I have a spare HDD to use with the copier, the only thing I am missing is the SST and the firmware.
      • Mb29661
        Ok, I understand.
        Could you help me out with the SST and the firmware perhaps. I am stuck here.
        • Mb29661
          Is there anyone interested in helping me?
          • CT Copier Repair
            • Mar 2010
            • 304
            very experienced IT specialists know nothing about copier hard drives and loading system software
            its not a Unix Linux Microsoft Apple kinda thing
            its a copier thing
            and as such call a copier guy
            • KenB
              Geek Extraordinaire
              • Dec 2007
              • 3944
              its a copier thing
              Well said!
              • Mb29661
                I understand that you are proud over what you do and I also understand that there are a lot of things that are not the same.
                If this copier i have had been at our office then i wouldn't hesitate to give one of you guys a call.
                But since it is in my home and I have plenty of time to learn by doing (wrong sometimes) I would like to do this myself.
                I am sure some of you understand what it is like to have a thing standing at home that you want to learn a lot about, and it is fun to explore a different field than you are used to be working with. I can't be the only one to feel like that when I have a new toy.
                • ymmtech
                  • Jun 2009
                  • 190
                  Try cloning if u have no firmware, backup your entire physical disk data, check SMART status, borrow a known good same model machine hdd, play with disk image.....
                  No harm to try even if it don't work.
                  • KenB
                    Geek Extraordinaire
                    • Dec 2007
                    • 3944
                    It may not seem like it, but we can appreciate your dilemma, feel your pain, etc...
                    Please don't shoot the messenger, but the manufacturers which we deal with do not allow us to disseminate such software, and there are some harsh penalties for doing so.
                    They don't discriminate between business and home users.
                    If they meant for the software to be distributed, they would post it on their website.
                    They quite often do this for the smaller, home grade devices (such as some scanners and all-in-ones), but there are some very clear rules about business class machines, such as yours.
                    There are countless posts about that on this site. To say that it is a common issue would be a gross understatement.
                    If someone wants to be the hero and give this to you, that's between you and them.
                    Personally, I like my job, and want to keep it.
                    • charm5496
                      • 2387
                      AMEN!!!!!
