Imagepress C1 - Leaking blk toner
  • MFPTech
    • 486
    This seems to b an ongoing issue.
    Any ideas, please?
    Thanks in advance!
  • teckat
    • 16083
    Any ideas, please?
    Thanks in advance!
    there was a change of Dev Units that had dumping issues-see pub.>TP08.pdf
    there was also a fix with a DCON update-see pub.>TP09.pdf
    when was the last time u replaced the Black Starter/ or replaced the entire BLK Dev unit ??
    what is the volume/?
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5018
      Any ideas, please?
      Thanks in advance!
      Leaking from where on what? Hooper,developer?Are you shore is black,maybe Waste Toner dropping?
      • MFPTech
        • 486
        Thanks for the info.
        Haven't been there yet, but called the customer and he said that the toner is leaking on paper and carpet, the previous tech that was there for the same problem just vacuumed the machine and now the customer wants the problem fixed, not just vacuuming.
        • gensys
          • Jan 2011
          • 323
          Originally posted by teckat
          there was a change of Dev Units that had dumping issues-see pub.>[ATTACH]9388[/ATTACH]
          there was also a fix with a DCON update-see pub.>[ATTACH]9389[/ATTACH]
          Thanks for all tech.doc
          The Road will be Mastered by >>> the Going...
          • zoraldinho
            • Mar 2008
            • 5018
            Leaking on the carpet?? Please report what kind of issue do you have.I'm curious.
            good luck!
            • teckat
              • 16083
              good luck!
