Error code E248-001
  • Peter Sim
    • Sep 2008
    • 445
    Error code E248-001
    Hi all
    Need help.
    iR2870 show e248-001.
    On the service manual ,it say reader controller pcb problem so i change reader controller,boot rom ,update the latest firmware,reseated all the connector and also disable the setting>copier>option>body>w/SCNR to 0 to comfirm whether is scanner or printer problem,but with no luck.
    Any idea or solution will much appreciate.
    Thank you in advance
  • teckat
    • 16083
    Originally posted by Peter Sim
    Hi all
    Need help.
    I believe you may have a power voltage supply to the Reader/
    check your 24v dc supply on Reader pcb.
    J500-supplies power to the ADF.
    J501 -receives power from the machine body (printer unit).
    J502 -communication with the machine body (printer unit).
    J503 -communication with the ADF.
    J504 -communication with the ADF.
    J505 -connects to the main motor.
    J506 -copyboard cover open/closed sensor; connects to the CIS HP sensor
    J507 -connects to original sensor 1, original sensor 2.
    J508 -connects to original sensor 3, original sensor 4.
    J510 -connects to the contact image sensor (CIS).
    J512 -for use at factory
    J513 -for use at factory
    check the interface power cable from reader to printer/ remove the cover off the cable & check interior connectors
    • Peter Sim
      • Sep 2008
      • 445
      Thank you Mr teckat for your info.
      I follow the instruction and the 24v was find.
      Try to change another piece of reader controller and the error code was gone.
      Is my mistake to change the spoilt pcb.
      • teckat
        • 16083
        After Replacing the Reader Controller PCB
        or
        After Initializing the RAM
        COPIER>FUNCTION>CLEAR>R-CON
        then,press the OK key to initialize the RAM. Thereafter,
        turn off and then on the main power.
        Enter the appropriate values using the following service mode items:service label (behind reader unit left cover)values.
        a-1. CIS read position adjustment (fixed reading)
        COPIER>ADJUST>ADJ-XY>ADJ-X
        a-2. main scanning direction position adjustment
        (fixed reading)
        COPIER>ADJUST>ADJ-XY>ADJ-Y
        a-3. shading position adjustment (fixed reading)
        COPIER>ADJUST>ADJ-XY>ADJ-S
        a-4. main/sub scanning direction MTF value
        COPIER>ADJUST>CCD>MTF-MG
        If the value of the following was not 0 before the
        replacement of the reader controller PCB:
        COPIER>OPTION>BODY>CCD-LUT.
        Set a value other than '0' once again, and make the following adjustments using the D-10 Chart.
        COPIER>FUNCTION>CCD>LUT-ADJ2
        ADF-Related Adjustment
        The machine keeps ADF-related service mode data in the RAM of the reader controller; as such, you will have to make the appropriate adjustments if you have replaced the reader controller or initialized the RAM.
        1) Enter the values indicated in the P-PRINT printout you have previously generated for the following:
        a. main scanning direction position adjustment (stream reading)
        COPIER>ADJSUT>ADJ-XY>ADJ-Y-DF
        b. original stop position adjustment
        FEEDER>ADJSUT>DOCST
        c. original feed speed (magnification) adjustment
        FEEDER>ADUST>LA-SPEED
        2) Make adjustments using the following items:
        a. tray width adjustment
        FEEDER>FUNCTION>TRY-A4
        FEEDER>FUNCTION>TRY-A5R
        FEEDER>FUNCTION>TRY-LTR
        FEEDER>FUNCTION>TRY-LTRR
        b. CIS read position adjustment (stream reading)
        COPIER>FUNCTION>INSTALL>STRDPOS
        c. white level adjustment
        COPIER>FUNCTION>CCD>DF-WLVL1
        COPIER>FUNCTION>CCD>DF-WLVL2
        When you have finished the foregoing adjustments, put the P-PRINT printout [1] you have previously generated in the service book cassette to replace the old P-PRINT printout.
        • Peter Sim
          • Sep 2008
          • 445
          Thank you very much,Mr teckat
