ir7200 scan
  • jiongpao
    • May 2009
    • 413
    ir7200 scan
    hi, currently the machine working fine with network printing but it cannot detect the ir7200 ip adress when using network scangear tool v1.5e, 1.6 and 2.0e. Is there anything i miss out to install in order to use scanning from computer? N bootrom install and ir7200N firmware loaded.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Try with color network scangear and scanner must be online.
    • ReproKev
      • 273
      Check for a firewall blocking it.
      You can also input the scanner ip address directly into the scangear tool instead of searching.
      • jiongpao
        • May 2009
        • 413
        color network scangear v2.61 used but no change it cant detect the ip even manually input ip address
        • D_L_P
          Self Employed
          • Oct 2009
          • 1196
          Scangear needs the device to be on the same subnet to work.
          Also, is the "scan" tab showing at the copier control panel?
          • teckat
            • 16083
            Network ScanGear Guide link
            Network ScanGear v2.21
            http://software.canon-europe.com/software/0028065.asp
            COPIER>OPTION>USER>NW-SCAN
            • Set to "1" to enable the scan tab.
            • Set to "0" to disable the scan tab.
            After making changes, be sure to reboot the copier for the settings to take effec
            • jiongpao
              • May 2009
              • 413
              Thanks i will check the scan tab, the setting and the new scangear. Will feed back soon
              • jiongpao
                • May 2009
                • 413
                "scan" tab is showing
                COPIER>OPTION>USER>NW-SCAN is in value "1"
                subnet mask is same with router
                I put scanner "online" and erase domain name on machine and using network scangear v2.21, it work
                im thinking of may be because i didnt go to "scan" tab and press "online" that why computer cant find the machine ip?
                or the domain name exist on copier machine while the computers are not using domain?
                • teckat
                  • 16083
                  Printer Needs to be/select "ONLINE" to Scan from PC/Mac-
                  • KenB
                    Geek Extraordinaire
                    • Dec 2007
                    • 3944
                    No Mac scanning - Windows only.
                    The copier does not need to be online for Network Scangear to find the machine and get set up, only when you actually go to do a scan.
                    Black and white imageRUNNERs require Network Scangear, and color machines require Color Network Scangear; they are not interchangeable..
                    Also, "Enable Dedicated Port" must be set to "On" for scanning to work - this one gets overlooked a lot.
