H1 Unit on CLC5151 shows "ffff"
  • V-P
    • Apr 2011
    • 679
    [Misc] H1 Unit on CLC5151 shows "ffff"
    Distant customer complains that H1 unit (piggy type) on the CLC5151 shows "ffff" on the RIP's display when they shoot down the RIP from the copier panel and does NOT turn off.
    It can stay like that for hours, unless you turn of the switch on the machine.
    Normally it should show ffff for a minute or so and than turn off.
    I don't remember well, but I think Canon released some patch or smth about this.
    Anyone has an idea ?
  • charm5496
    • 2387
    you are going to have to reload the H1 to get it running. The latest firmware is version 2.0
    • V-P
      • Apr 2011
      • 679
      yeah I have it.
      Thnx man !
      • charm5496
        • 2387
        the only thing else you could try is to remove the battery from the H1 motherboard to see if it will boot up that way, but since the machine is so far away from you I would just reload it. You may want to take a HDD with you as well incase it is defective.
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3945
          Seeing how it's so far away (as we can all well relate!) make sure that you have the current system firmware and SST for the MFP, just in case it's not current.
          The H1 version 2.0 is kinda picky about that, as it was a somewhat major update. (I had one of my techs install the version 2.0 without first updating the firmware first... it wasn't pretty). There's a tech pub on this, but who reads those, right?
          Make sure you have the software patches for the H1 as well.
          • teckat
            • 16083
            H1-
            FF/Code-Check external and internal connections and cables.
            if u re-load H1 Firmware and issue is same- u have a bad H1 Motherboard
            • V-P
              • Apr 2011
              • 679
              Thnx guys !
              I will schedule a visit and bring the tools with me.
