print like zebra line
  • zamamd
    • Jul 2008
    • 7
    hai everybody, my copier machine ir 6020i print like zebra line.first printing 1 to 50 is ok after that it will print like a zebra line on A4. i try change carona transfer wire.now it alway printing very bad.how i can solve the problem.some here have this problem. maybe HVT board or CCD board problem have the problem.some expert can tell me........
  • jonezy999
    just one copy??
    • Feb 2010
    • 952
    An example? Check what you did wrong to the transfer charge initially.
    I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
    • gensys
      • Jan 2011
      • 323
      Attach problem page to yours post
      The Road will be Mastered by >>> the Going...
      • jiongpao
        • May 2009
        • 413
        i got same problem before, u must totally clean all around the transfer and primary including all the straps
        • D_L_P
          Self Employed
          • Oct 2009
          • 1196
          If the "zebra" like line is what I think it is, vacuum all the toner out of the hopper and developer. Those zebra stripes (usually toward the edges) happen when genuine toner is mixed with aftermarket toner.
          • teckat
            • 16083
            Wavy Lines=
            if in paper feed location on copies and prints/
            check your laser scanner assembly connectors/ and pins on connector
