iR3300 jam 9011
  • harnrak
    • Aug 2009
    • 32
    iR3300 jam 9011
    I had a copier iR3300 jam 9011.
    Help with
  • dhanesh
    • Jun 2010
    • 63
    9011 means?
    DHANESH
    • mrfixit51
      Lead Service Technician
      • Oct 2008
      • 1975
      Originally posted by dhanesh
      9011 means?
      FF: Types of Jams
      Code Type
      00xx none
      01xx delay jam
      02xx stationary jam
      0Axx power-on stationary jam
      0Bxx cover open jam
      9003 logic jam (*1)
      9011 logic jam (*2)
      10xx finisher jam
      *1: standby jam from the Finisher-J1.
      *2: image request absent jam.
      I have never seen the jam you are listing, perhaps you can provide more information regarding the situation under which it occurs...
      • teckat
        • 16083
        Help with
        If code 9011 occurs without Paper Present.
        Jam Code 9011 try the following troubleshooting steps:
        Re-seat the DIMM's on the Reader Controller PCB.
        Re-seat the connectors on the Reader Controller PCB.
        Clear RAM on the Reader Controller PCB. To clear RAM on the Reader Controller PCB enter Service mode >Copier >Function> Clear >RCON.
        Before u clear RCON =do print out of P Print settings to re-input back in-
        If the Jam Code 9011 is still present it may be necessary to replace the Reader Controller PCB.
        9011=Image Request Absent Jam
        If paper is present or printed out with jumbled text-
        May be a faulty Differential PCB on the Controller Box Assembly
