iPRC1 E020-0x85
  • pga
    • Jul 2009
    • 67
    [Error Code] iPRC1 E020-0x85
    Dear All,
    Do anyone faced this error code before?
    I had changed
    1) Drum unit
    2) Patch Sensor Unit
    3) D-kit Harness Unit
    4) Cleaned ATR sensor
    5) Potential Sensor claeaned
    Anything/steps that i was missed out? Kindly assist on this matter. Thx in advance.
  • teckat
    • 16083
    Originally posted by pga
    Dear All,
    I had changed
    1) Drum unit
    After Replacing or Cleaning the Patch Image Sensor, don't forget to execute FUNCTION>MISC-P>PT-LPADJ (this adjusts the initial volume of reflective light for Patch Image Detection).
    Check the Sensor Shutter to make sure it moves freely and that the windows for the Front, Center and Rear Sensors are clean.
    Check the operation of the Patch Detection Shutter Solenoid SL8 under COPIER>FUNCTION>PARTCHK> SL (8). The Solenoid can be isolated by temporarily removing the Shutter while checking the Sensors.
    Check DISPLAY>DENS> PCH-LED1, 2 and 3, each location should have a reading similar to the ones
    below.
    PCH-LED1: 161 (Front Sensor Window)
    PCH-LED2: 211 (Center Sensor Window)
    PCH-LED3: 148 (Rear Sensor Window)
    If one or all of the readings for the Front, Center or Rear Sensor are “0”, this is a clear indicator that the Sensor Assembly or its wiring is faulty. Exchanging the position of the Sensors is quick way to see if the faulty Sensor moved and to determine if the Patch Image Reading Sensor should be replaced.
    NOTE:
    If one or all the Sensors in the Patch Image Reading Sensor are defective, a new Patch Image Reading Sensor Assembly should be installed.
    I have seen defective units sent out-
    READ PDF>>>>
    TP09.pdf
    • pga
      • Jul 2009
      • 67
      Thx for replied,bro teckat. I have tried and followed the steps but still not solve. It was intermittent appear.
      • teckat
        • 16083
        make sure interior contacts of DRUM touch shaft
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5018
          Dear All,
          I had changed
          1) Drum unit
          Teckat already say this but check again dude.This issue have a lot of times.Inspect P-kit black plastic cover.Probably it's broken.
          ipc1-048.pdf
          • teckat
            • 16083
            Remove the shutter from Patch kit/ throw it in the garbage
            replace the three-P KIT CABLES/ they get damaged
            FM2-7221-000
            1 CABLE, P-KIT,
            FM2-7222-000
            1 CABLE, P-KIT,
            FM2-7223-000
            1 CABLE, P-KIT,
            • zoraldinho
              • Mar 2008
              • 5018
              • kraudy
                • Aug 2011
                • 5
                iPRC1 E020-0x85
                Dear All,
                I had changed
                1) Drum unit
                Dear all,
                Hello, i have the same error code on IPC1, i like know how Mr. pga can solve the problem.
                Thanks.
                • zoraldinho
                  • Mar 2008
                  • 5018
                  Re: iPRC1 E020-0x85
                  Originally posted by kraudy
                  Dear all,
                  Thanks.
                  Yeah,me too.Did you check all mentioned above?
                  • DANIELCANON
                    • Jun 2011
                    • 187
                    Re: iPRC1 E020-0x85
                    Tambien puede ayudar esto:
                    *28*
                    copier
                    fuction
                    dpc
                    drm_rset------------para inicializar el tambor.
                    • teckat
                      • 16083
                      Re: iPRC1 E020-0x85
                      *28*
                      copier
                      fuction
                      dpc
                      u don't want to do that >
                      see above>>>>>>>also
                      E020-xx85
                      Patch image sampling (center) error 1. When the value of DISPLAY>DENS>DENS-SY/ M/C/K (patch image
                      measurement value) - DISPLAY>DENS>D-CRNT-P (dark current measurement value) ≤ 30
                      1. After cleaning the Patch Sensor, execute FUNCTION>MISC-P>PT-LPADJ.
                      2. Select DISPLAY>DENS>PCH-LED2, and check the value of PCH-LED2.
                      3. After removing the Patch Sensor Shutter, execute FUNCTION>MISC-P>PT-LPADJ.
                      4. Select DISPLAY>DENS>PCH-LED2, and check the value of PCH-LED2.
                      5. If the value is more than 240 replace the Patch Sensor Shutter and Patch Sensor Solenoid. Then,
                      execute PT-LPADJ again.
                      6. If the value is within 80 and 240, the operation is completed.
                      7. If not, replace the Patch Sensor.
                      8. Execute PT-LPADJ.
                      imagePRESS C1 / imagePRESS C1 Printer / imagePRESS C1+
                      Updated Troubleshooting Descriptions for E020 Error Codes
                      • teckat
                        • 16083
                        Re: iPRC1 E020-0x85
                        imagePressC1-STANDARDS & ADJUSTMENTS
                        • kajsa39
                          • May 2008
                          • 28
                          Re: iPRC1 E020-0x85
                          Hi Gents
                          just been reading these threads because I also have the same problem on a C1 ever couple of days, Ive changed and done all of the above statements but am still getting the error E020 0485, any suggestions.
                          Many thanks
                          Kajsa39
                          • teckat
                            • 16083
                            Re: iPRC1 E020-0x85
                            Originally posted by kajsa39
                            Hi Gents
                            Many thanks
                            Kajsa39
                            have u done a BLACK DEV. CHANGE ??
                            READ THIS-----SEE ATTACH FOR TROUBLESHOOTING E020
                            (01 = Y, 02 = M, 03 = C, and 04 = K)
                            04 is for BLACK----------
                            E020-0485 Patch image sampling (center) error 1.
                            When the value of DISPLAY>DENS>DENS-SY/ M/C/K (patch image measurement value) - DISPLAY>DENS>D-CRNT-P (dark current measurement value)≤ 30.
                            Execute This below------------------
                            completed.
                            • kraudy
                              • Aug 2011
                              • 5
                              iPRC1 E020-0x85
                              Very thanks,
                              i resolve the problem removing de cover of the sensor path, i am waiting for the solenoid to replaced.
