Newbie to ir5000i
  • chopkins052
    • Aug 2025
    Newbie to ir5000i
    Hello,
    Just received a Canon ir5000i from a company as a donation. Do not know anything about this copier than it makes copies. So i need a lot of help.
  • icopier
    • Apr 2011
    • 45
    Originally posted by chopkins052
    Hello,
    That's a workhorse which i have a friend who have been running it for over 5 years!
    • jonezy999
      just one copy??
      • Feb 2010
      • 952
      What do you need help with?? Is it working?
      I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
      • chopkins052
        It is working but there are lines on the copies. Just want to know if there is a way I can clean it without calling a tech.
        • jonezy999
          just one copy??
          • Feb 2010
          • 952
          Could be anything from that description.
          Can u describe the lines better? Are they a clean and straight line? Do they run the entire length of the page? Exactly how are you using the machine when the lines appear?
          • chopkins052
            I am making copies. The lines seem to be disappearing now. I added toner. The lines are not on the whole document but maybe at the top and the bottom. They are not straight lines. They have missing parts on the lines.
            • kucinggarong
              Re: Newbie to ir5000i
              try to make black copies. it helps to determine what is wrong for example if the line is white then try to clean the corona.
