I have had this problem with 2 machines now. For some reason i will make a copy on the glass and copies fine but i will run a copy through the ADF and the copies come completly blank. When i switch the ADF machine runs fine what is in the ADF that causes this.
3300
It sounds like you may have a problem with the size switches on the ADF. The switches that sense 11 x 17 may be constantly closed. That will make the machine give you a blank copy when an 8.5 x 11 sheet is run through the DF. The machine will copy the trail edge of the 11 x 17 sheet first thus giving you a blank if you are copying onto 8.5 x 11. Try copying the 8.5 x 11 original onto a 11 x 17 sheet and see if your image shows up. That will tell you if this is the case. Also, when you switch ADFs, does the problem show up on the other machine?
Get back to us and let us know.
Good luck.
